BGP.DecisnCoord.StorNbrPfxMaxExcd
Description
The maximum number of prefixes allowed from a given peer would be exceeded by processing a received update. If the peer is configured to drop the connection in this case, then the connection will be reset. Otherwise, the received update will be dropped.
Remedy
Increase the number of allowed prefixes or limit the number of prefixes using more restrictive policies for this peer.
Severity
Warning
Message Text
[VR %p1%] The maximum number of prefixes stored for a neighbor would be exceeded.\nNeighbor IP address: %p2%\nAFI: %p3%\nSAFI: %p4%\nDefined max prefixes: %p5%\nDropping connection: %p6%\nIdle hold time: %p7%
Message Parameters
Name Type
p1 uInt32
p2 VarFmtByteArray
p3 uInt16
p4 uInt8
p5 sInt32
p6 sInt
p7 uInt32
p8 String
